Hoefler
- 20
- 38
- White Bear Lake,MN
I like that last picture-6 Sigma at work!
Pete
Pete
No kidding, TWM, your shop is SO clean, it looks like you're working in a Clean Room or a Hospital Operating Room or something.Today was spent putting the final paint on the bell housing, parking brake parts and axle tube clamps. Then I disassembled the T84 transmission and inspected each part since I did see evidence of water penetration. Finally tally showes an order for $305 in tranny parts will get the job done. Still cheaper that a $950 rebuild.
Here are some pictures:
Your method (laying out the parts and labeling them) is so much better than mine...(throwing everything in a box and hoping it's still there when I need it)Today was spent putting the final paint on the bell housing, parking brake parts and axle tube clamps. Then I disassembled the T84 transmission and inspected each part since I did see evidence of water penetration. Finally tally showes an order for $305 in tranny parts will get the job done. Still cheaper that a $950 rebuild.
View attachment 578203 View attachment 578204 View attachment 578205 View attachment 578206 View attachment 578207 View attachment 578208 View attachment 578209
I have no doubt that Tinwoodsman would assemble a qualified team of specialists to join him for the precision undertaking:Pete, call me when you need work on your appendix.
It wasn't a problem; I used my left eye to read one and my right eye to read the other:Sorry for the dual posts. Cockpit problem.
I ran a few searches through Google, but no luck.It truly amazes me that Ford stamped his mark on virtually every part on the GPW Jeep. I am fortunate that my vehicle has most of the original and stamped parts but to show you the extent of this, I am posting the first photo which is of two small clutch tube metal disks about 1/2" in diameter. Notice the script "F".
No Pete. It is a Dana 18You can take my appendix out only if I get to lay on that nice quilt with those super nice brake lines.
Is that a Dana 20 transfer case?
Pete
I made lots of things to go into places never to be seen again and did strive to put my mark on the stuff I made. It means that with everything taken into consideration it was the best that could be done at the time. Most of my stuff was in ships and subs and in the now torn down powerplants steam and jet engines. It is OK. Maybe one day Zout or others will find something and look into the marks on it because that part of it still works.....seems to be more than just a copyright mark; almost like it was a matter of pride or something.
OK...here's the story I heard/read/made up. On the GP's Good ole Henry actually had "FORD" in script letters embossed on the rear panels of his jeeps but the government wanted the GPW (Ford) and the MB (Willys) to be identical with 100% of the parts interchangeable and no trademark name on the jeeps.I ran a few searches through Google, but no luck.
It seems to be more than just a copyright mark; almost like it was a matter of pride or something.
There has to be a good story behind the stamping practice, and I'll try a few other leads for the explanation.
You bet; and I get it, absolutely.I made lots of things to go into places never to be seen again and did strive to put my mark on the stuff I made. It means that with everything taken into consideration it was the best that could be done at the time. Most of my stuff was in ships and subs and in the now torn down powerplants steam and jet engines. It is OK. Maybe one day Zout or others will find something and look into the marks on it because that part of it still works.
