Smokinyoda
- 8
- 18
- Franklin, NC
I just added a 12v alternator to power my bed crane, lights, backup camera, etc and am in the process of wiring it all up. It is a 60 amp 1 wire alternator and I want to wire in a 24v relay to turn it off and on with the trucks master switch. Since its a 60 amp alternator I need a continuous duty 60 amp relay correct? Reason I ask is all the pictures Ive seen of other peoples setups most use the little black plastic bosch or hella type relays, and I cant find one in 24v that goes up to 60a. Only thing I have found in 60 amps is the big metal solenoid that looks like the ones used on older Fords, and for CUCV glow plugs.
So what do you electrical gurus out there recommend?
