Official 2015 Ga. Rally buy/sell/trade thread
Al Harvey
19
Dover, TN
I will be bringing the following items this year. Please PM me if you are wanting something. I will update this post as things are sold. The price is each unless otherwise stated.
900 Series Tie Rod End Set (1LH 1RH) x 2 $75 a set
Trailer Wheel Cylinder M146, M118, M119, M373, M270, M345 NSN 2530-00-776-0966 x6 $50
HMMWV Rear Cargo Cover $50
Drawer from Shipping Container x 5 $85
IMG_2823.jpgIMG_2822.jpgIMG_2824.jpg Length 45"IMG_2825.jpg Width 17"IMG_2826.jpg Height 11"IMG_2827.jpg
M809 Drag Link Repair kit NSN 2530-00-244-1315 $35
M809 Rear Brake Hose NSN 4720-00-740-9331 x2 $10 --- SOLD Ferro x2
M809 Tach Cable NSN 6680-00-882-0966 $20
M809 Throttle Hand Control Cable NSN 2590-00-405-9763 $20
M35A3 Inner Wheel Bearings NSN 3110-01-399-1253 x4 $50
M35A3 Outer Wheel Bearings CTIS NSN 3110-00-399-1251 x3 $50
M35A3 CTIS Brake Valve NSN 2530-01-419-6303 x3 $20
M146 Window $120
HMMWV Speedo Cable 117" NSN 6680-01-442-9413 $35
HMMWV Transmission Dip Stick NSN 6680-01-184-9214 $10
HMMWV Transmission Dip Stick Tube NSN 4710-01-188-3238 $10
900 Series U-joint kit for Driveshaft (Transfer to Rear Axle) NSN 2520-01-082-8619 $35
800 Series Steering Knuckle Boot Zipper Type NSN 2530-00-832-7123 x2 $20
Al Harvey
19
Dover, TN
I will also be bringing a few ammo cans. I have many available and will bring more if requested. Again please PM for requests. I added a picture with tags to help identify which can is which and also added the dimensions of the cans.
40mm (18 1/2"L x 6"W x 10" H) - $15.00
20mm (18 1/2"L x 8"W x 14 1/2"H) - $20.00 (Swiss x3)
60mm (15"L x 6"W x 19"H) - $14.00
81mm tall (14"L x 5 1/2"W x 29"H) - $15.00
81mm Brown (25"L x 13 1/2"W x 8"H) - $15.00 (73m819 x3) (Coffey1 x 1) (Swiss x 1)
120mm tall (12"L x 6"W x 31 1/2"H) - $17.00
Pictures show a 50 cal can in front for reference. Next is 40mm, 20mm, 60mm (on right), 81mm tall (on left), and 120mm. These cans all have good seals and most look like one time use only.
This is the 81mm brown box with a 50 cal can for reference, 3 50's would fit inside on of these if you pulled out the foam pieces.
Wanted to add this about the 81mm Brown boxes. They do not have seals. Also they have vent holes on the front and back and the latches are designed to be locked with wire. Any questions please ask.
Also I will be bringing a bunch of new general maintenance CUCV parts to sell at the rally.
CARNAC
The Envelope Please.
620
Corpus Christi, TX
Unless I get a job (Can't get no job man)(just kidding) that requires me to start before the rally, it looks like I'll make it this year.
I tried to go back and edit my initial "What I want" post but can't and besides, who went back to look and see what I wanted anyway.
I plan to have
-Two to Four pallets of Fat 50 ammo cans (price TBD)
-MRAP seats (my last ones)
-Artillery version of the VIC-1 intercom that has the 4 or 5 flip switches on the crew boxes and the special amplifier main box.
-Two of the big round tent heaters (pot bellies)
-DRASH 5XB tent (NOS)
-M1009 tailgate
-M1009 tire/wheel assembly
-Several boxes of Harris antennae but don't know what's in the boxes yet
-Two RT524 radios (not demilled but haven't been powered up in over 3 years)
Streamline
107
Comer, Ga.
I plan to have
-M1009 tailgate
Im Interested in condition of M1009 tailgate? Im in Need.
Also interested in condition of Fat 50's and price for 1 2 3 or all 4 Pallets? One can never have too many cans!
Thanks Bobby
juanprado
2,867
Metairie/La (N'awlins)
1980 Military M101A1 3/4 ton cargo/utility Trailer. $840
Solid tub and frame with no rust or cancer. Tub has rear ding on left rear. New style A2/A3 tub with reinforcement ribs. Not the original as military appears to have refurb this trailer. Paint decent. I touched up some bad spots.
Lunette has been flipped down & Standard size 235/85/16 radial tires with 95% tread. Tires can be found anywhere instead of the military 900x16. Tows level for most vehicles since with smaller tires and lunette flipped it is at civy height.
Has 2 heavy duty safety chains. 1500 lb dual wheel fold a way tounge jack.
Trailer has heavy duty working parking brake on each wheel. Hubs and bearings ran cool on 4 hour recovery with no issues.
Tail ,brake, add on led license plate lights are 12v with standard 4 prong flat connector with leds to verify hook up. All new wiring in loom jacket from junction box to tongue connected with military connectors so it can be easily switched back.
military 12 pin harness & bulbs for taillights for +$40
Military equipment is underrated and over built. I have carried over 4000 lbs in one and did not even strain or sag the springs. Easy to pull and a dream to tow with.
has 2 shocks on axle to dampen cargo. I can change and put new monroe lifetime warranty gas shocks for +$70
One long board is wood on one side. All others are fiberglass. Bow storage pockets on front missing on one side. I added the rear gates and they are wood. 3 metal bows and staves. 2 are wood.
I might have a cover available for extra fee. I am in the process of purchasing a cover but not sure when it will be in.
Trailer has a valid Maine license plate and registration. No title as Maine does not require one on a trailer this old. I will give new owner bill of sale, old registration and plate. Perfectly road legal and transferable to new owner.
Will bring to GA Rally for a serious buyer with a hold deposit. Green cash money or certified check.
CARNAC
620
Corpus Christi, TX
Now corrected from my horrible blackberry typing.
-Three medium towbars with pins
-I have at least 1 set of Y feet and possibly some other feet but will only sell with a towbar
-Grounding rods (a bunch)
-About 8 HMMWV pioneer racks
-Claymore bags with the wire and wire spool
-Real authentic simulated (yep, real authentic simulated) blasting fuse, I think it is called M23
-Metal part of the gates for an M101 series
-1 each stub wooden side rack for a 5 ton
-I have some things that I think are pintle risers and there are two different types
-M16 bandoleers the newer 4 pocket type, like the ammo comes packed in
-Two M720 dolly sets
-DRASH generator/air conditioning trailer
-S280 in superb shape
-S280 in good shape
-Two original MB jacks (there's a history with them)
Heading back into storage in the morning so we'll see what else pops up.
lostnbfe
Decatur, AL
Crate is 77"x 41.5"x 60" tall and two soldiers can eventually lift it, to load/unload on a pick-up truck.
Also lifting devices to put on truck may be on hand, at the yard and at the rally.
G.
Gerhard,
It will probably fit in the bed of my m1028. Is it 77" long X 41.5 wide x 60" tall?
Alan
gringeltaube
Staff Member
2,468
Montevideo/Uruguay
Good to know, thanks! And yes, that's correct.
Please also contact Ford Mechanic via PM; he's the one interested - and working-out the logistics, for this.
G.
swiss
763
Oakwood, Ga
Anybody passing by Springfield Mo on the way to the rally? Might have a pickup that could use some assistance getting to GA!
