Problem connecting RT-524 to VIC-1
CommoChief
39
Sayre, PA
I am trying to connect an RT-524 to a VIC-1 system. The problem I am having is the jumper cable from the center jack on the RT mount
is a straight plug and the power connection (jack immediately to the right) takes a cable with an angle to the left. Therefore, the two plugs
will not work together as the power cable interferes with the jumper cable to the VIC-1. My question is...would it be easier to find a different
base/mount for the RT-524 with different jack set-ups or look for a straight power cable?
Thanks in advance....Bill
86humv
512
Texas
Later Sincgars cables have a bend to them, and the older cables don't.
You probably have a sincgars cable.
Wile E. Coyote
78
Lynden WA
Yes, but don't change the orientation too dramatically or you'll stress/ break the wires. The power cables are far more resilient to stress than the intercom interconnects. I've had a number of them that had broken wires due to their being torqued too far.
CARNAC
The Envelope Please.
655
Corpus Christi, TX
I was seeing them on ebay but just did a search and can't find it.
I have/had two sets but I still haven't unpacked from the move and we're probably weeks if not months from unpacking all the tool stuff. I will be at storage tomorrow and if I find it, will let you know.
They are a set of 6 or so semi-circular sockets all held together by a round bar/pin that is also used as the spanner handle. They have a kinda saw tooth edge on the bottom. Of note, they were a lot smaller than I expected, after all they fit inside the cable connector. I tried to find a photo on line but can't find any.
