- 456
- 0
- 16
- Eustis, Florida
I have recently been ask to lead up a project of restoring four M35A2. I will take pictures and provide more details on the trucks.
For or now Starting the project off on the wrong foot. The trucks have set for a period of at least 10-15 years. After conducting level one maintenance on all four trucks which consisted of draining and replacing the fluid, cleaning the fuel tank and fuel system, and replacing the filters. It's been a busy weekend. However the crushing blow was that three of the trucks are getting fluid to the secondary filter but not to the injectors.
Injection pump
After cleaning the fuel lines, I tried a few tricks that have learned over the years. Started with the fuel shut off. I noticed that the was some rust and debri inside the inspection cover. The fuel shut offers ceased on all three trucks. I was able to get the shut off un-ceased, but still no fuel to the injectors. I then attempted to bleed the ip head with bleeder still no fuel. I then check the ip button which was in working order. I conducted a check of the fuel advance and governor cover and found old dirty fuel. I was at my knowledge end.
I had a buddy call a recently retired Sergeant First Class Mcccormick. A veteran of the Florida National Guard for around 40 years. He was a 91B, and is by all means case expert on the ltd 465. His wealth of knowledge was amazing. He advised me of gasket on the drive train and to replace them in half the time. The most amazing part was when he took a a specialty tool for removing the fuel lines from the injection pump out of his pocket. I will take picture and show the tool. Awesome seeing this veteran reunite with the M35s
Unfortunately the three injection pumps will need to be rebuilt or replaced. I have fund a few of them around 900 to 1200 dollars. Does any one have any good surplus or rebuilt IP for a good price?
I will will keep all of you posted and will provide pictures.
Injection pump
