- 1,450
- 119
- 63
- Gray, GA
From what I can tell, the switch below the pump in the picture is the pressure switch for the ether system. Is that correct?
If so, is that the only thing it signals? Can it be removed and plugged if I'm not worried about the ether system working correctly.
In the picture you can see it's leaking from the connectors. I not interested in replacing the switch for a system I'll never use, unless it will affect something else. I'd rather just remove the switch and terminate the wires if possible. I can't find a definitive answer on whether this is possible though.
