I would think if there's air in there, it would nearly fall back down . Same issue with the hand pump?That's not my issue. My issue is after rebuilding the pump the cab doesn't want to raise, and when it did, it didn't want to drop back down. Making wonder if there is air trapped inside
it doesn't raise only to a certain point, so Yes I am sure there is air in there, but how to get it back out?I would think if there's air in there, it would nearly fall back down . Same issue with the hand pump?
Does anyone have any idea where the rebuild on this pump is?I believe it's self bleeding the pump and reservoir are one. Are you having an issue with yours? If you see puffs of "smoke" coming up then your internal pump seal is bad and will need to be rebuilt. There is a thread on it.
yes, it's right hereDoes anyone have any idea where the rebuild on this pump is?
