- 518
- 179
- 43
- Stoneville, NC
I bought one of the Meguiars Headlight Restoration kits a couple weeks ago. After using it to polish a couple regular vehicles I started looking at my LMTV and figured why not, might as well see how much difference it makes. If you haven't used one of these type kits, you are wet sanding the lens using progressively finer grit, then use a special polish, then a protectant. I had to use a knife to scrape the CARC off the edges. The turn signals in the front cleaned up very nicely also, but I can't get a good picture because of how the truck is parked. Here are the before and after pics. I still need to clean up the bolt heads on the housings, and put in some cheap LED replacement bulbs. I like the look of these old style lenses vs the new LED units.
