paraclete comes
- 4
- 18
- southern ca
So i pulled the trigger on a new factory battery and figured to just cry once. I switched over the cables and hooked the new battery up, filled up the fuel and oil and replaced all the filters. The old girl fired right up without any issues after just a few tries. I did notice the shut down switch didn't shut her down so I had to open the cover and manually shut it down. Also have a pretty decent oil leak at the drain spout, so I will have to give it a look and see whats going on. Best case maybe a new gasket or O-ring, worst case I will just pull out the old RTV and seal the old girl up.
It seems to be running a little rough but I need to fix the leak first and then run it longer. Also had the oil pressure light on but figure thats due to the leak? So its a project and I'm having fun and hopefully its a reliable little unit.
