7th times the charm?
74M35A2
330
Livonia, MI
I have a set of new XZL's off the 923A2 donor truck and a rear Marine axle assembly with a Detroit.
Also, as it turns out, a 923 Radiator will fit well in the <Jim> nose... feel like we're carving up a buffalo here ;).
Did you know that a Bluebird Bus air to air inter-cooler fits well in the nose of the 939 series? Plan is, a bigger turbo (HX40), turn up the fuel and get more cooler air into this puppy. My younger brother is a Cummins tech, so it will be done well.
The 6CTA8.3 already comes with an HX40 turbo. Next step would be HX50, HX52, or HX55. I'd say HX50 if auto trans. But, an HX40 can make a lot of intake boost. I think some people are nearly at 40psi or so. I'd reference the drive pressure (exhaust side) before just swapping it out. Any pics of this bus intercooler in place (bus model/intercooler part number)? I have been waiting for somebody to spec one that fits decently enough to use. I even went with a roof mounted A/C condenser unit to keep the radiator front open just for an intercooler.
Thanks.
73m819
323
gainesville, ga.
This will take a while to build... as I have a few in front of it.
JeepNasty and I have been swapping trucks around for a year or so. I love the 8.3L Cummins, so I bought a M931 winch truck from JN as an engine donor for a friend's project... well, since it's a running, driving winch truck, I have issues taking it apart. One of the projects in front of it is Diamond Jim, a 1958 Diamond <T> 923 tractor. My friends have taken to calling it <Jim>.
We're putting it on a 278' wheel base Peterbuilt 379 low air leaf Chassis and building a very large sleeper behind it, so it looks a bit like this:
Which of course, leaves a quandary... what do I do with the clean winch truck that has a PTO on it and the boom/winch from <Jim>?
I have a wrecker, but she's a very heavy pig. I have a friend that could use a heavy off road recovery rig. Heck, I could use one too... at least I tell myself that.
So, the plan is:
Bob the axle, use spare front and rear air ride I have, add the rear winch, Dayton hydraulic set up with boom from <Jim>, intercool the Cummins and turn it up a bit. Should be a fun little ride.
Oh, here's the truck:
I ended up buying another one of JN's trucks, a cargo truck with a rotted cab. That engine and trans is going into a 1950 <T>... probably turn the bed into a dump trailer that can haul cars behind this.
What a SHAME to carve up the DT, that is a classic in its own right, Does the DT have a weighted front bumper as a counter weight for the rear lift.
