- 75
- 0
- 6
- stratford/CT
Hi there will the winch level wind off of an m816 wrecker fit the winch im putting on my m923a2? the winch im installing came off of an m932a2
I don't, I sold them together. The are a little more difficult to find, and not very low cost. It was going to be like $700 or so to buy both used. Entire 925 front cut off came up in classified that had a level wind on it. I bought it all for $700 because I wanted the hydro winch for the rear anyway. Tried the level wind, didn't like it, sold it for $500, and now have extra the 925 winch and frame extensions for $200. (Frame extensions for sale for $300 now ).I am totally going for the look wont be using the winch that much. Do you still have the level wind and tensioner? if so want to sell it?
My hood and grill cleared the front level wind on my 925. I have seen a different prop rod length available, not sure if that is just 923/5 difference, or if it is for the level wind. Possibly mine had a level wind prop rod to begin with.don't forget the correct length hood rod . or you will smash the grill up .
There we go. That is why it worked for me.The different hood prop lengths are for winch or no winch and do not have anything to do with the level wind. A winch hood prop will work with a level wind.
I know someone that had a wrecker front winch rigged that way, it really screwed up the winch.You do not wrap the rope backward to use the level wind. Top of the drum rotates toward the grill to pull.
