low coolant light
Hogg
Ardmore, OK
I've got a low coolant light issue on my M1009... Plenty of fluid in radiator and in resevoir... The light comes on after its warmed up a little, then goes off and comes back on randomly... Im assuming its a sensor problem, but i'm not the saviest of mechanics... Any suggestions or anyone with the same problem??
rnd-motorsports
Evart,Michigan
Unplug the sensor as stated its on the pass side tank of the radiator if you ground the wire that is pluged into it, the light should come on and unground it should go out.with the key on, if it does change the sensor. common complaint would almost bet its the sensor!
Barrman
1,782
Giddings, Texas
Clean the end of the plug too. Mine was intermittent, then constant. I did the checks in the -20 and put in a new sensor. All good for about a month and then it started coming on every now and then. I cleaned the plug, crimped it a hair with pliers and now all is good again.
Hogg
Ardmore, OK
Low coolant light issue
I recently posted a question about the low coolant light in my M1009... It comes on and goes off randomly, plenty of good clean antifreeze in the radiator and in the reservoir and no signs of it getting hot... A few guys told me to replace the sensor, and I did. Took it out for a cruise this afetrnoon, and thought I had fixed the problem as it didnt come on for about ten miles, then it came back on and started the same ole thing all over. Got home, checked the wire that connects to the sensor and couldnt find any bad spots where it might be grounding out... I am perplexed to say the least... Any suggestions??
doghead
4 Star General /Moderator
1,179
Yes, continue your old thread.
Edit, I merged them.
cjkeeliii
Thomasville, GA
I had the same problem, and the fix was to clean the connection under the dash. If memory serves, there are a couple of black boxes under the dash, one of which is close to the steering column. On my truck it is not connected and occasionally falls down around the brake pedal. Anyhow, one of those connectors in that box is for the low coolant sensor. I unpluggged the connector, applied dielectric grease, and dumped all of the dirt out of the box. Hope this helps you.
cucvrus
10,437
Jonestown Pennsylvania
An old thread but I have the same issue on Terminus M1009. The low coolant lamp in on all the time. The previous owner put black tape on the cluster over the light to hide it. I want it to work properly. Any other ideas? Also the temp lamp over heat does not come on when I start it and the horn blows constantly when the fuse is in place. Even with the horn relay removed. I am lost on that one. Any ideas? I mean I can spend countless hours and figure it out I am sure. I am asking for some helpful hints to resolve these issues.
cucvrus
10,437
The horn still blows with the horn relay removed. That is why I am confused. The horn relay is the little 3 prong relay. Unless I lost my mind. OK I seen the other thread. I will cut the relay diode on top of the plug. I have the steering wheel apart to clean the contacts and repair the spring and small black lock on spring and contact was missing. Also the column lock is very dirty and neds lubed. That will make the key turn easier.
The low coolant light does not go out with the wire unplugged or when I ground out the wire. if I am correct the grounding out should be what makes it go out?
The high temp light I am not real worried about. I will work on that again later. The circuit board was a bit thin on the copper at these 2 areas. that could be the problem with the low coolant lamp also. ???
Warthog
232
OKC, OK
There is a circuit board for the low coolant light. It is near the horn relay and fuse box. It is about 1/3 the size of the glow plug card. I have seen them get very corroded. Remove it and check the contacts.
At one point AntennaClimber had talked about building new ones but I do not know if that ever happened.
cpf240
Free in Northern Idaho
The horn still blows with the horn relay removed. That is why I am confused. The horn relay is the little 3 prong relay. Unless I lost my mind. OK I seen the other thread. I will cut the relay diode on top of the plug...
If the diode failed with a 'short' condition instead of an 'open' one, it is bypassing the horn relay altogether.
