M48 & M983 HEMTT Differences?
rumplecat
221
North West Arkansas
I don't have the fever yet but a HEMTT may be unavoidable! I use my tractors more than anything else so a HEMTT tractor would be what I would like. I see the M48 power units and then the M983s, is the 983 just a fixed tractor?
HASSON1911
24
roseau/mn
Get a M985, I got the M977 and after having it thats my only gripe is to have a larger crane. Unless you specifically want the tractor then the M983 that is.
73m819
319
gainesville, ga.
Yes, there are TWO 983s, one has a standard 2" fifth wheel and crane, the OTHER has a 3 1/2" fifth wheel, no crane
jasonjc
289
Gravette Ar.
A M48 is a 2 1/2 ton truck tractor or a tank depending.
A Mk48 is a FPU (front power unit) you would also need a Mk16 RBU (rear body unit). The Mk 16 is a fifth wheel RBU they also have a Mk15 20'flat bed , Mk 17 has a 16' bed with a crane and Mk18 is a self loader.
They are both hard to find. You see 20-30 cargo hemtts to every 1 tractor hemtt.
You'd be better off with a M931/M932 5 ton or a M915 or M916. The M915A3 are real nice.
dk8019
55
Lovettsville, VA
Hasson, makes some sense, however the limit is what, 2500lbs at 19'? With the boom in it is 4500lbs, I think, and I believe I could grab a jeep or some other small 4x4 and drop it on.
Regarding the mix of tractor HEMTTs or MK48 w/MK16 RBUs, by my quick calcs, 65% of what has been sold so far is cargo units (985 and 977s), 28% have been tankers, and 4.5% have been Tractor HEMTT or Mk48s. 1.8% has been just power units.
73m819
319
gainesville, ga.
The MK15/15a1 is the WRECKER RPU for the MK48/MK!5 truck.
The 20' flat bed without the crane is the MK13/MK13a1
Augdog1964
15
Richmond, IN
Small correction to post above, Mk48 flatbed is a Mk14, not Mk13 or 13a1, to the best of my knowledge no Mk13...
Mk 48 LVS = FPU
/14 = flat bed container carrier unit - no crane
/15 = recovery unit - crane
/16 = tractor unit - no crane
/17 = cargo unit - crane
/18 = container retriever - no crane, but container picking hydraulics
Shark Bait
59
Charleston, West Virginia
Mk 48 LVS = FPU
And the 16 fifth wheel rear body unit has winch.
DrillerSurplus
Salt Lake City. UT
Originally Posted by Augdog1964
Mk 48 LVS = FPU
Rounding things out- the original MK18 lift mechanism is cable operated like a lot of older roll off trucks, the MK18A1 RBU uses a hook mechanism very similar (maybe identical) to the HEMMT PLS.
rumplecat
221
North West Arkansas
Back to the 983's, what are the easy to recognize differences in the 2 and 3.5 king pin variants? I see some of them have vertical exhaust stacks and others have the exhaust laying horizontal across the bed behind the cab?
73m819
319
gainesville, ga.
Real easy, the 2" has a crane in front of the 5th wheel, no crane = 3 1/2" 5th.
Castle Bravo
Hundredaire Socialite
215
Arizona
There is also the M983A2 LET, with the 3.5" fifth wheel and winch, much like the MK48/16. Though I haven't seen of them surplussed yet...
rumplecat
221
North West Arkansas
So I have yet to see a 983 with a crane come up for sale on Gov. Planet, are the 2 in. vehicles pretty rare or just not yet surplussed?
Castle Bravo
215
Arizona
That variant pulled the Pershing missile system and that went away in 1991, so maybe they're all already gone.
