- 179
- 19
- 28
- Gilroy, CA
Would like to run higher tire pressure on my tractor when on road, is this as easy as swapping the control box?
Is there any public or known know-how on this? Software, connection cable, procedure, parameters that can be calibrated, etc... Thanks.If you can find one from a wrecker thats programmed to the higher pressure. Not all are. Any controller can be reprogrammed you just need the Y cable to interface a PC to it.
Will
http://www2.dana.com/pdf/AXTS-0015.pdfIs there any public or known know-how on this? Software, connection cable, procedure, parameters that can be calibrated, etc... Thanks.
