reelclassic
- 2
- 8
- Jacksonville, Florida
I recently purchased a LMTV with a 3126 Caterpillar diesel. I am missing a couple parts and need help with serial numbers. There is a bracket
that holds the CE Neihoff alternator to the block. I have the bracket that the alternator attaches to with long bolt and smaller bolt - but there is another small bracket that holds it to the block. Also, there is a bracket on the front of the engine that holds the tensioner and pulley. Really need help determining part numbers for
these. On another note, is there a trick to starting the LMTV. When I press the red ignition button I get nothing. Do you have to hold the brake pedal???
Thanks for your help!
