I started at the back of the truck in the tailgate area where you wouldn't be able to paint once the gate was closed. I then moved the other inside of the bed and got as much of the interior as I could reach, then the rear wheel wells. I then painted the passenger side up to the windshield and moved to the drivers side to do the same.
That's when I made very important discovery.....1 gallon of behr wont paint a hmmwv. I ran out at the B pillar and had to stop for the day.
The next day after getting more paint I got inside the truck on the center tunnel and repainted all of the areas that I wasn't happy with from the day before, I also painted the overhead ribs (this was really not necessary but it was bothering me having them black and the truck green).
I then closed the tailgate and painted the rest of it that I did not get the previous day. From there I picked up from the previous day and painted the drivers side to the windshield and the front of the windshield with the hood raised. I painted the front wheel wells and the top of the hood while it was raised. The I lowered the hood and painted the front of it.
After that I just went around the truck touching up anything I didn't particularly like.
This paint is very forgiving and covers excellent, and the paint gun is awesome!
I have the bulkhead that I removed from the 2 man setup to practice the patterns with and that really helped.
Once everything was dry I the got the patterns out of the TB 43-0209 color markings. I lined everything out in chalk and made sure what color went where.
Yesterday I painted the brown the first, again starting at the inside and moving out and did all of the brown. this took less than 1 qt of paint.
Once that had a little time to dry I cleaned the gun and swapped over to black. and again got inside the truck and painted the outside last.
This took 1.5 qts. I did these colors with the hood down so the lines matched better. One thing to watch is covering the chalk. If you don't get a heavy enough coating at the edges then the chalk will show through once its dry.
I hope this helps anyone wanting to try this pattern. This was a first for me and it wasn't bad at all. I was a little scared of messing it up but its a very forgiving pattern.
