seek
- 0
- 6
- Mocksville nc
I screwed up. I was taking my genny out for a walk and I have it configured 120v 3phase with one 4 outlet boxes hanging on each side of the genny frame one off each leg.
So I had two heater connected one on each side. I cranked it up got it all dialed in and applied the load and saw I needed to add in my kill a watt as I find both convenience outlets dead. so I go for putting it in the side outlet and then bam a big spark (i musta missed) and that side is dead, breaker tripped. I brought the breaker back on, but that side stays dead. Other side working. load at 60%, 60 hz, 125v.
Could I have burned up something generator related or did I more than likely fry the box? Its a stout box. It vibrates so bad and with a low skill set I want to wait until I run it for what I set out to do and then look into it. I am so happy it did not mess with me. It was fire within.
In the connection photo L2 is N, and I have the outlets grounds in the green nut run to a separate ground.
I could not stand it and went and tested the outputs and I am getting 125v there abouts on each leg so I guess something in that box gave away. Gosh i hope thats the case. The boxes are hanging by their straps wrapped around the frame and I am going to have to put something behind it to hold them steady for me. I missed them moving target apparently. I guess I tested it correctly using the meter's red probe to black and black probe to white. My genny sits on rollers and it vibrates a little more than i think it should..better than mice nests.
thanks for your input
