- 5,637
- 381
- 83
- Spring Branch, TX
Looks good! Remember this moment when it's back in and started for the 1st time.
When I was greasing mine the first shot pushed the zerk out of the hole. It apparently wasn't threaded on just sitting there. Luckily nothing was stripped and I was able to put it back on and worked fine. There are definitely some that are a bit trying to get to.Also noticed the u joints in my knuckle between the transfer case and the tranny had no grease zerks, just plugs and it look like they had never been greased, they look ok so added some zerks and should be good to go.
Also a reminder to all don't forget about those two grease zerks on the shifter, hard to see when it is installed, you should be able to see them in this pic.
It's been full of water....The inside of my transmission looks like the inside of m38inmaine"s motor. More bad news, at least this answers the question why it would not shift at all.
There was no oil in it at all, looks like none in there for a long time, this goat gets better and better
