rustystud
- 2,987
- Woodinville, Washington
With this 10 lead generator the way R Racing has it connected is the only way you will be able to use 240 volt single phase. By using 2 of the main leads out to power your furnace you will need to use the third to power something of equal value. I know there is a way to run a "low zig zag" WYE circuit from this generator I just cannot find the diagram. You cannot run the "double Delta" though.
