CUCVLOVER
- 9
- 38
- west Tennessee, just outside Milan
Good lord.
Where did you go?
Videos?
Where did you go?
Videos?
Good idea, all though I would have just welded ah bolt. Just buy 5 bolts when your at the store and stick one in a marked sandwich bag, and throw it in the glove box. Or better yet drill an another hole in the plate for the extra bolt with ah nut on the other end.Going wheeling/mudding what ever you want to call it you will always see my winch mounted. If it is covered it will not be an issue with mud and will be usable right away, been there many times. I am not going to try to carry a 120lb winch from where ever I have it stored to the front of my CUCV in a mud hole, not worth my safety of falling. The reason to make it removable is to prevent theft or flat towing with a tow bar. There are many ways to lock it down, a good chain and pad lock to an eye link on the plate, or just wrap it around it. You can also weld a small curved plate to block one of the bolts on the winch (See video). This is for the fools that do not know the plate is removable, but if you do not secure one of the bolts they can just unbolt it.
Do not get me wrong, I like this idea and it looks great and will be good for people that do not have tools to build them. But I almost never take mine off and just leave it covered.
https://www.youtube.com/watch?v=WvcGsUVyBnI
I want one of these if you have started selling them.Any word on the completion of these mounts? I am really interested in one for my M1008.
Colorful use of adjectives. I like it and agree with the video host.Going wheeling/mudding what ever you want to call it you will always see my winch mounted. If it is covered it will not be an issue with mud and will be usable right away, been there many times. I am not going to try to carry a 120lb winch from where ever I have it stored to the front of my CUCV in a mud hole, not worth my safety of falling. The reason to make it removable is to prevent theft or flat towing with a tow bar. There are many ways to lock it down, a good chain and pad lock to an eye link on the plate, or just wrap it around it. You can also weld a small curved plate to block one of the bolts on the winch (See video). This is for the fools that do not know the plate is removable, but if you do not secure one of the bolts they can just unbolt it.
Runs off of the power steering pump. Makes full power when the engine is at idle...Hey Glock.
That sure is a good looking truck. How did you get hydrolic power to run it?
How did you do that? ThanksRuns off of the power steering pump. Makes full power when the engine is at idle...
it just becomes a part of the power steering/hydroboost circuit... too easy.How did you do that? Thanks
So you just T into the pressure line and run it to the windshield check and do the same for the return?it just becomes a part of the power steering/hydroboost circuit... too easy.
