Jeepsinker
- 438
- 83
- Dry Creek, Louisiana
That's the same hood as is on the multifuel equipped five ton I'm cutting up right now.
It was never specified what gasser it was. So if you say it's a 5 ton now, that's fine. Old age happens to us all.you all do realize, we are talking about a 5 ton gasser?? old.
The MT600 series are longer and much heavier then the AT500 series . I have a MT654 from a Tanker truck which I thought at one time I would put into the deuce, but this thing is just too big ! Also the AT500 series transmissions are not electronic ! The only electrical is the neutral safety switch.Hi Guys. Up here in Canada, our MLVW's ( 2 1/2 tons) ran with Detroit diesel 8.2 litre fuel pincher engines and an Allison MT643 automatic transmission. Now I know that our engines were not multifuelers but earlier in this thread you were talking about different styles of bellhousings for different engines. Also it appears that the general population does not like the current automaic running in your A3's ( reliability issues, electronically controlled ). Maybe this transmission could be an option if the bellhousings match up. This tranny has no electrics on it and is full mechanicl shifting with govenor controlled internal hydraulic pressure.
My 2 cents
Driving an Allison is not like driving the automatic in your car. You need to read the Allison drivers manual. You can, and I do, shift an Allison manually.I've driven a bit it parades, in the deuce you can crawl pretty slow with the transfer case in low. Not much clutching is needed if you leave enough space in front of you.
Automatic transmissions are my comfort zone, that's what I grew up driving. But a couple years back I drove from Fort Campbell to Sill in a moving truck with an Allison, often I longed to be able to manually shift it on my own. "I can shift gears better than this!" crossed my mind a few times.![]()
oops i meant CAT!Cummins? The A3 doesn't have a Cummins!![]()
You could go with the 2000 series. It is longer then the stock manual though so you will need to modify the transfer-case position and adjust the length of the drivelines. They are good transmissions though with very few recalls done to them.Read through this entire thread again.
What about one of the modern six speed allisons? The 1000/2000 series and up would be more than up to the task and with a .61 and .64 overdrive with stock sized tires it would perform great as the gear jumps are smaller and dont loose momentum. There is many companies that offer aftermarket support and stand alone controllers at reasonable costs.
They are great looking trucks. I have never seen one for sell though have you ? Does the Canadian Government even allow the sale of their trucks ?I want one of those Canadian deuces! I like my five speed standard, but the Detroit is neat.
Not that I have seen. In fact I have seen Canadians complaining they can't buy them. Though this is just my reading. I'm not 100% this is the case.They are great looking trucks. I have never seen one for sell though have you ? Does the Canadian Government even allow the sale of their trucks ?
To bad.They used to surplus them years ago, then things changed to be just like HMMWVs used to be here, they all had to be destroyed. So there are a number of them out there in civilian hands, just not as many as we have of ours.
Now in that case I would keep the detroit.Hi Welldigger. The Canadian Deuces had an 8.2 litre Detroit fuel pincher 4 stroke engine, not a 2 stroker. Although I have heard of some people have installed a 6V53 into them,maybe someone up in Alaska. Anybody know for sure?
the biggest and really only issue i see besides hving to move the transfer etc is the flexplate. 2000 series allisons can be had all over with SAE 3 and 2 bellhousings, but correct me if im wrong the flexplate from the multifuel has to be unique to that engine series.
Do you know how to get in touch with him ?Rusty, you just need the flexplate off of an LDS465-2. Mike Parra has one he doesn't need.
