Lebowski
- 3
- 8
- Manitoba Canada
I found this red blazer on CK5.com. Says 35" tire no lift but he did have to do some major fender trimming.
![](http://i199.photobucket.com/albums/aa176/argetlamfricai/1973%20K5%20Blazer/0820091141-00.jpg)
Guess im not sure what you mean? None of our rigs are all that great off road?Pavement Queen. Only thing it has going for it is the full top removable. I will be doing that conversion someday Maybe. Then again maybe NOT.
As long as you move your axle foward and are not shy with the cutoff wheel you can make them fit with little to no lift. One other thing, with zero rates you may need to trim a little off the threaded portion of your drag link ball joints. When you move the axle foward you have to shorten the drag link to match. Some of the ball joints (MOOG) will need a little trim so that they don't bottom out when adjusting the drag link turnbuckle.Definitely think the back will be fine stock. I'm curious about the zero rate, moving the front axle forward an inch seems like it would help alot... and they appear to give 1" of lift too. I'm curious if coupling those with the heavy duty shackles which seem to add another 1/2" http://www.offroaddesign.com/catalog/hdshackles.htm would be sufficient to avoid the 4" lift option. Maybe with a wee bit of trimming instead of chopping into the inner fender....
