How to clean out old pics
73m819
323
gainesville, ga.
How in the He!! do you clean out old pictures out of what ever so new ones can be posted, this sucks, what is the point of posting a build if you can not post pictures to go along with the post.
4,803
There's no need to use profanity. Why are you not able to upload pics? Are you clicking on manage attachments? In there you can review all the images you've uploaded. And you can click to remove individual images if need be. But there should not be a limitation to the number of pics you can upload. There are however a limit per post of images. If that's the case, and you want only certain images in the specific post, you'll have to click on manage attachments and remove the images you wish, then upload the ones you wish. But I'd like to have a better understanding of what your issue exactly is?
73m819
323
gainesville, ga.
I up loaded 10 pictures at a time as per the instructions, the first 10 and the second 10 were fine, they downloaded 10 in each post a they should, the uploader would only allow me to up load 6, which I down loaded, could not up load any more, when I deleted the first 26 by accident, I was then allowed to upload the rest of the pictures which I down loaded in the post to ONLY then to find out that my first 26 pictures were GONE. It seems that I have about 400 pictures, most if not all are OLD because I have not done the picture thing because of the hassle involved since the "upgrade"
73m819
323
gainesville, ga.
As faw as I can see, there is NO WAY to delete old pictures, I can copy, save as, link to, and a few more options but NO DELETE
4,803
There's only 20 images allowed per post. Outside of that, you'll have to make an additional post. But I'm not sure how you were prompted to upload another 6 images since the 20 attachments per post is global. (Even I can't post more than that per post) Please make sure to only do 20 at a time.
And as to the "upgrade". The "upgrade" only happened a few years now. It's not going back (couldn't now even if I tried, and not going to due to the broken php in the last version). Matter of fact, they'll be upgrades to come.
dmetalmiki
2,028
London England
Patracy. Hmm, I just went through all the proceedure you outlined..and NO there is NO option to delete as instructed. Any further advice on how to actually delete old unwanted pictures?. Thanks in advance.
73m819
323
gainesville, ga.
I only uploaded 10 then down loaded them in a post, then uploaded 10, then down loaded that ten to a second post, then tried to upload the next 10, but was only allowed to up load 6 which I down loaded to a third post, then afterscrewing around trying to make "room", I found that after I accidentally deleted the first three down loads, I could further upload the rest of the pictures in batches of ten. as each batch 10 was uploaded, I then down loaded the 10 in a separate post, then went for the next batch of 10, then again to a separate post, AT NO TIME did I try to upload or download more the 10 ????? Just seems there is not enough room, at least that is how it has acted.
4,803
For historical purposes, here's a screenshot of my previous post.
So here's how to manipulate the images. Click on the edit of the post in question, then click on manage attachments. The full fledged attachment manager will open up.
You can see the pic I uploaded there. If you hover over it, you'll see the X on the top right to remove it. (Added the red square and text of course to this pic)
Once you click on that you can remove the image from the post. If it's embedded with the {attachment} tag (only in [ ] marks) in the post, you'll need to remove the embed as well or it'll reinsert it. Notice the verbiage just above the attach window, if it's not used within the hour it's deleted from the system.
73m819
323
gainesville, ga.
I can pull pictures from post BUT can NOT dump them from the picture storage after they are there for a while, that is how I deleted the first 26, the rest have no delete option
4,803
Correct. If the image is used elsewhere on the site, it remains. If it's not, then a cron (automated) job will clean it up from the server. If you uploaded a pic and then went back and deleted it years later, the cron isn't going to pick that up.
bikeman
501
Ft. Bragg, NC
I think the issue is, there's no way to delete pictures in the uploader you uploaded a long time ago...
And the whole "it'll be deleted in an hour"...
I've attached a picture I uploaded sometime in 2011 or 2012, when I was at Ft. Sill for EW school.
73m819
323
gainesville, ga.
This seems to be the problem, the storage is full, why I do not know BUT it is full and will anymore uploads till some stuff is dumped, the ONLY stuff that is allowed to be dumped is NEW stuff, the OLD stuff needs to go, the new stuff needs to stay ???
4,803
Manage attachments with the pop up window allows for 10 image uploads (or other attachments). However if you use the Quick Reply window and click on the image icon above it, you can embed up to 20 images per post. Course this is done image by image.
4,803
There is no limit.
73m819
323
gainesville, ga.
So I can go around Manage attachments where a full uploader will not affect the post ?, still HOW do you clean out the up loader
4,803
You can use the picture icon above the text window in either quick reply or full reply. (Middle row of icons between the two world icons and the quote bubble icon) This will give you the option to insert an image embedded into your post. (Or delete the embed and it will remain in the post as a attachment in the attachment window) You do not clean out the uploaded images. There is not a limit to uploads here.
dmetalmiki
2,028
London England
Nope! all those instructions and page posted showing a red x do not work. I (and I presume we all) Do NOT have a small red x at that top right. I (We) Do have a blue question mark ? where you had a red x is all. so NO option to delete.
