- 6,426
- 4,983
- Ft. Lauderdale, Florida
Does one use the inserts with the ferrules when using the air brake line? Or is the original type fitting better with the air brake line. Can the original type, Parker Hannifin nut sleeve 61HD fittings be used with air brake line?All you need is some air brake line and crush collars. 1/4" for the returns between injectors, and 3/8" for the supply lines.
