3 or 4 finger pressure plates
Floridianson
2,514
Interlachen Fl.
Nah, neither plates need adjusting(to my knowledge), its the linkage in the clutch peddle that needs it.
Reading ALL of the TM it says if the pressure plate was resurfaced! I never planned to take apart the pressure plate and rebuild it from scratch like the TM said. I just ordered new. New no adjusting is what I did and no problems. Yep correct adjusting of linkage and you can leave the inspection plate off the bottom after install and watch to make sure the throw out bearing is not spinning with engine running.
