- 179
- 19
- 28
- Gilroy, CA
Experienced an intermittent power loss, then two shutdowns with the truck today. At first, the truck felt like the pedal became disconnected from the throttle. No power. Coasted to the side of the road, and truck continued to idle. CEL, and engine shutdown were lit. Shut it down, then got out to take a look. Everything seemed fine, gauges were all good. Couldn't see a problem.
Fired it up again, and took off. Felt just like normal, until a half mile down the road it did the same thing. This time the truck turned itself off, and I noticed the gauges and lights all went dead, then came back on all by themselves.
Was limping back home when it shut off again, and would not restart for 10min or so. During this time, the ignition key or battery switch would not power anything. No lights, no gauges, totally dead. The CEL and Shutdown light were lit before the truck turned off.
After that, I drove it home the last 10 miles like nothing was wrong. Seemed totally fine and ran great.
After reading through the DDEC portion of the TM's I can't seem to find out how to make the truck flash codes to the operator. Tried jumping pins A and M, then turning ignition on, and depressing the check engine button, but nothing happens. This seems tricky to diagnose without being able to get the codes. Any tips on that?
