My MEP-802a recovery from Fort Drum & work though to start project. Documenting here.
Well i recovered my 802 yesterday with no major hiccups. I would like to start this thread to detail the recovery process and will also be documenting the steps i'll take hopefully to fet a nice runner going.
802 made in 2000.
22 hours
M116a3 trailer
Recovery in Fort Drum
EUC approval total time approx short of 4 weeks
First i'd like to say how cool Paul the Govplanet onsite contact was. Very polite, and assisted me in lifting the lunette up to set into the pintle while my friend backed the truck up. Real cool dude. Very respectful, and i would be surprised if he wasn't former military. Good american.
Drive time from my house in upstate NY to Ft Drum was 3 hours. I took a measurable amount of tools, a jack, cross bar, 4 gal pancake compressor, fix a flat, tire plugs, honda eu2000i to run compressor if needed, wood blocks of assorted sizes etc.
After towing for 30 min, i checked hub temps. 125°F. Warm to touch but not hot. 20 minutes later i checked again but only by touch. Driver side hub was warm enough to get worried and passanger side was on its way. Very warm to touch but not quiet hot.
I decided to pop the dust caps with a short flat head screw driver and a hammer and check the condition of the bearings and grease. Upon inspection, the grease was new but i felt there wasn't enough. There was fresh red grease towards the front of the castle nut but the grease at the bearing was a darked almost brown, and had oozed away from the bearing as if it were poorly packed. I pulled out disposable gloves and axle grease, and started shoving grease past the castle nut until it grease was past the castle nut. I applied the same process on the other side.
After driving another 30 minutes and rechecking, temps leveled off and seemed to have cooled down so i made the decision to continue home. Upon arriving at home some 3.5 hours from start, the hubs were warm enough to the touch that at a very firm grasp, i could hold my hand for about 4 seconds before it was uncomfortable and i pulled off. My fingers were 'late fall cold' so the temp difference between my hand and a warm metal hub probably accounted for this. From what i have heard, and read from old timers, this is still safe but would warrant a look see at those temps. I'll be removing the bearings and repacking this spring.
Upon review, i have a large assortment of accessories which came with the genset and only three small things missing. I am missing the radiator overflow reservoir cap, the lower copper pipe for the auxilliary 50 gallon drum bung adaptor, and the split lug wrench for the output lugs. I have a call in to Delks for the parts already.
Upon inspection, it looks as if the genset in fact only has 24 hours on it. I see no evidence of tampering anywhere and i hope to get it running soon.
Here are pics of my loadout. I'm happy.
802 made in 2000.
22 hours
M116a3 trailer
