gottaluvit
- 24
- 38
- Bethesda, OH (AKA: Flyover Country)
M929A2. Okay, I know to drain the third down first, then fourth down, then first one, then second one down. Thing is I have been doing one at a time, and by the time I get to the third and fourth to be drained, the tanks are nearly empty. I hear something let loose two or three times (varies) when draining the first two to drain. The last two I drain are so low on pressure by the time I get to them that it would seem to me that they don't get to purge much water out. I would think you would get more water out if it hissed for a bit.
Should I just start with the proper order but let them all go at once, or am I doing it right by letting each tank drain completely? It seems as if, by me letting each of the first two drain completely, that they are in fact draining a good bit out of tanks 3 and 4 of the sequence.
Could I have an issue with some check valve? Or am I just overly concerned with nothing?
Jim
Jim
