grayparatrooper
- 0
- 16
- Dallas tx
He lives far and not available for a couple weeksYou had a second person there in the third pic.....? Just have somebody start it for 3 seconds and looky where it is coming from. Doesn't look like it will be hard to find. Looks like NHC 250 engine.
Not very it was spuing out lolWow That is a mess! I would look first in you coolant tank to see if there is oil there. How long did it run to make that mess?
Where does one find that?Check your crankcase vent tube. I have seen plugged up ones blow fill cap off and blow oil out from top like in your pics.
Gray, I texted you a bunch of pictures for things to look at.Where does one find that?
You need Dexter, the blood spatter analyst from the Showtime series to trouble shoot origin of where that splatter emanated!! Sorry, I know you are probably miserable, I am not trying to make fun of a crappy situation.Didn't start it for a month charged batteries started it up and the giant mess that you see. Anyone locally wanna come trouble shoot? Really needs 2 people and be nice to have someone who actually knows what their doing lol.
i hope you joking about the epaThat much oil on the ground will require the appropriate EPA petro-chemical spill reporting.
That oil looks like it needed changing anyway, I have the spin on oil filter adapter kits listed in the classified, perfect time to upgrade the filter.
Keep us posted.
EPA spill report requirement is 10 gallons, so he's ok as long as he used proper spill containment methods.That much oil on the ground will require the appropriate EPA petro-chemical spill reporting.
Keep us posted.
I'm in carrolltonWhere are you in Dallas ?
Im northeast of you.
It's a commercial property and no storm drains are nearby if that makes a difference. Used about 100lbs of that oil-dry or wtvr it's called right after anyway.EPA spill report requirement is 10 gallons, so he's ok as long as he used proper spill containment methods.
