gjones
- 0
- 0
- Amelia, Ohio
The speedometer doesn't work and the tranny seems to only shift to 2nd gear. I'm thinking "Vehicle Speed Sensor". And if so, where is it? Any idea's guys?
No Speed sensors on CUCVs, or related modern electronics, that is what many of us like about them.I'm thinking "Vehicle Speed Sensor".
For the shift issue check your vacuum lines from your vacuum pump, to your regulator on your injection pump, and from there down to the modulator on the right side of your tranny.
Mg's suggestion to check vacuum though to modulator is a good one on the shifting.
The cable was broken at the transfer case. Just got the new one in. And the tranny was over 4qts low. Replaced the 1.5" of vac line at the modulator. From there its metal up to the engine. Don't see a vacuum pump. Only thing I see running off the 2 belts are the 2 alternators and the power steering pump.
The vacuum modulator is probably going bad. They can be adjusted by removing the vacuum hose and inserting a small straight screwdriver and turning the adjusting screw in or out.The new cable was the answer. The speedometer now works. Shifts to all 3 gears, but whines up quite a bit before it shifts to 2nd and 3rd. Going to service the tranny and check the vac. line at the vac. pump next.
