Deuce turbo issues
rustystud
2,815
Woodinville, Washington
There is no "turbo" pressure regulator. The housing on the left side of the block has a relief valve that opens at 40 psi (dumping excess pressure back into the pan) and a valve that opens at 15 psi minimum for the piston cooling nozzles. The turbo is fed off of the same system as the engine bearings, etc.
Your right, my bad !
I just got back from Hawaii when I posted that so my mind was still adrift ! I need to medicate myself when flying as I get really sick due to inner ear damage. I wonder if that turbo supply hose is internally damaged causing a restriction ? I know it comes off the main pressure galley so there should be good oil pressure there.
JasonS
139
Eastern SD
I haven't done it myself, but next time, ask your doctor for something to make you sleep the entire flight.
rustystud
2,815
I have these special patches that I wear plus some pills for anxiety. Though that flight from Hawaii was a bad one. Half way here it hit a really bad area. So for half an hour we where rocking and rolling ! People started throwing-up all over the place ! I was pretty medicated but I was even starting to get sick ! I really hate flying ! I wouldn't have even gone if it wasn't for the fact my wife's parents (who still live there) are very old and in poor health. We figured this would be the last Christmas we would have with them.
whatadeuce
Loxahatchee, Florida
Short of using a pre-lube set up to protect my turbo bearings against dry start ups, I am advised o add LUCAS oil stabilizer, so as to maintain a very slippery turbo bearing surface for each engine start up,
rustystud
2,815
By just adding the spin-on oil filters you will almost eliminate the lack of oil problem due to oil drainage from the canister filters. Personally I don't add any engine oil additives except for "zinc" . The modern engine oils do a great job of lubricating the engine especially the "synthetic" oils.
jetman10
swanville,maine
Hi guys . I have a deuce with a "D" turbo and would like to change to a "C" . I have a chance to buy a new one reasonably . Thing is, I don't know the difference by just looking . I finally found two pictures of both . Is the one with the Marmon clamp in the center the correct one ? Thanks .
rustystud
2,815
Hey RUSTYSTUD, are you using synthetic oil in your MV engine? Which one?
Right now I'm using "Rotella T" full synthetic 5-40W oil. I also use "Delo" synthetic 10-40W . It just depends who has the best price when it comes time to change the oil. Just be sure to use a "diesel" rated oil. Diesel oils must deal with more contamination then gasoline engines do.
com54
Sea, Wa
OP when the truck is shut off what temperature it is at? Turbo coking from high egt shutdowns kills turbos.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I am not sure. My buddy put the D turbo back on and gave up on troubleshooting. I thank everyone for their input.
