New clutch
bluewv
ocklawaha florida
Hello all , I need help to find the right master clutch set for my M35a2 1982 ldt 465 engine. There is a lot of them on ebay but I wanted other people's input before I bought one. Thank you.
gimpyrobb
dumpsterlandingfromorbit!
27,786
757
Cincy Ohio
I'd check with Teds trucks down in Nc, they have always been fair with me.
If you search 231556054044 in egay, you will find a good kit.
chestypuller1371
Butte Alaska
how can you tell fiber from the ceramic?
what kit did you und up using? anyone just reuse the pressure plate? is there a more desirable pressure plate 3 or 4 finger?
rustystud
3,074
Woodinville, Washington
The best clutch plate would be the 6 disc model for the 5 ton, but the next best would be the 5 disc model. The best clutch pressure plate is a toss-up. The standard 4 finger model is a good unit, it just needs to be adjusted. The 3 finger model is also good and more then likely you will not have to adjust it. It also handles being out of adjustment better then the 4 finger one which has a tendency to break fingers when out of adjustment. As far as "reusing" a pressure plate that is a bad idea. They tend to get hot-spots and will cause either a grabby or a slipping clutch.
The way to tell a ceramic from fiber clutch is the ceramic looks like metal, while the fiber looks like normal brake lining.
Wildchild467
57
Milford / Michigan
I am in the process of putting a new clutch in my truck as well. I have the 3 finger stamped pressure plate and 6 puck ceramic clutch disk. Ill drop the flywheel off to be machined today and I have a new ring gear on order as well. My ring gear was chewed up in a couple spots which explains why I had one rebuilt starter grind a couple times. now I know why it acted up and its actually a good starter.
