Okie Cowboy
- 0
- 0
- Mountain Park Oklahoma
I found a solenoid to replace the bad one. I want to ask if I should use new starter bolts when I put starter back on?
When checking the steering check the frame where the steering box bolts on they are known for cracking .It lives once again. I changed fuel filter cleaned battery terminals and connections charged batteries and fired it up. I also found out that the block heater works.
I'm going to replace the battery cables and few more things under the hood.
My next issue I'm going to address is play in the steering.
Thanks to everyone that came to my assistance.
