tim292stro
- 41
- 48
- S.F. Bay Area/California
That sounds better than 2Ga for jumping.
I have some 4/0 clamps (1400Amp) I'm going to build a set of jumpers for - I tried jumping a friend's 5.0 Mustang with a Toyota Pickup and that taught me something... More battery, more alternator, more cable thickness - always a good thing
For the slave cable set I'm building, I have a LED circuit in the heads which change color if the polarity is not right, or the voltage is too low.
- Red = Reverse Polarity (center negative instead of positive)
- Green = Good polarity, voltage above 18Volts (probably a 24V system)
- Blue = Good polarity, voltage is too low (might be a 12V system!!!)
