DemocracyEnaction
- 2
- 8
- Rio Vista,Ca
Ok just saw this. What's the transmission governor filter?
http://www.steelsoldiers.com/showthread.php?133133-Allison-Governer-screen-filterOk just saw this. What's the transmission governor filter?
Do you have a part # for the governor filter?
What is it about the door? Is that some sort of armor?I got the cover on finally. But the rope was toast. So I need to get new rope. I just tired it down with regular rope for right now.
Also had to go run some errands. So I thought it would be fun the drive through some of the snow in the parking lot.
Just my opinion, but by you asking stirring those who know the answer to help, by answering, you have helped folks like me who didn't even think to ask. So you did help.Just ordered the part from ebay.$8. Thanks again I too hope some day I'm able to contribute instead of just ask questions.
Yeah its armor.What is it about the door? Is that some sort of armor?
I'm liking that.Yeah its armor.
I picked it up that way. It also had an armored box in the back with a mount for a M2. I need to change out the cradle for a 1919a4. Until I get a M2I'm liking that.
Your work, or did you pick it up that way?
Ok. I get it. All part of being a gun truck. Nice!I picked it up that way. It also had an armored box in the back with a mount for a M2. I need to change out the cradle for a 1919a4. Until I get a M2
They are designed that way. They are not set up like a civy vehichle. It is a very easy mod to do to get them to work that way. I assume you have a m939? Abandon the original wire feeding the turn signal running light from the original harness. Y off the side marker light to the turn signal running light. It now comes on at the same time as the marker light. Enjoy the increased safety and visibility.trouble shot my headlights.. found i had a bad dimmer switch. yay the headlights work now; however, now the parking/marker lights wont come while the headlights run. they only come on in the parking lights position on the switch. even tried swapping it out with another switch. hmmm..
I was hoping the snow would be frozen so I could park on top of it. No such luck. It looks ók with the regular rope. But I am looking for some super rope. A lot easier to use than regular rope.@SpyderMan, looks good, even with "normal" rope! Yeah, driving over things with these trucks must be a blast.
