Did you have the GND disconnected without the jumper wire in place?No it does not, I tried that when I was jumping the wire. When the horns started to blow I disconnected the ground and the horns continued to blow.
A jumper across the diode will cause the horn to sound. I would remove any jumper and disconnect 25A at it's ground point. Then see if that stops the horn from sounding.I'm not sure, 25 was connected to the solenoid,and 25A ground to the firewall was disconnected.
Lol. Good idea, best of luck.I'll try that after Mom gets out of bed! I think she'd kill me if I started blaring those horns when she's in bed!
Power ia always supplied to the solenoid from wire 26 as you mentioned. GND is supplied to the solenoid through wire 25 when the horn switch is pressed as you mentioned. Wire 25A is tied to GND, has a reversed polarity diode, and connects to wire 25. The reverse polarity diode should not allow GND to reach the solenoid which would cause the horns to sound. However diodes sometimes short internally when they go bad. The reason for removing wire 25A from GND is to be sure a shorted diode is not causing the horns to sound.I have no schematics to look at and I'm on my phone but I keep thinking the horn button in the steering column simply grounds to activate the horn isn't the power on whenever the ignition switch is on so where are you disconnecting the ground
If this is the case then the horn switch is providing GND to the solenoid when not being pressed. Figure out why this is happening or get a switch that doesn't do this.The only wire that will stop the horn is disconnecting 25 from the horn switch located at the bottom of the steering column.
Correct, however he says wasnt sure whether or not a jumper was in place which would cause the horns to sound. That is what I wanted him to confirm. Now that he has explained removing GND from the horn switch stops the horns, it's obvious there is contact through the switch when there shouldn't be.So if he tried it with the diode disconnected and it still went off, it sounds like the problem is in the wire going through the steering column. which could be simply tested with an ohm meter.
