Kaiserjeeps
- 7
- 28
- North Idaho in the woods
I put a warn 12K winch and mount on a neighbors Dodge today. Before I installed it I parked the winch carrier in front of my CUCV for a look.
It fit great. It has enough spread to weld on two square tube sleeves for the shackle mounts with some minor metal work. Then can be tied in to the upper grille guard bolts for a little more support. Or bolted to a spreader piece welded in across the upright mounts on the brush guard. The part number is #62027 and is roughly 225.00 bucks. It looks super simple to make it work.
Here are some pictures. Hopefully photobucket will display the pics correctly. I just posted on another site and it worked fine. That happed last time my pics failed to show here. Anyway...
Hardly any impact on the overhang. Does not block the radiator as the 12K winch lays in the tray. It's feasible.
The 15K winch fits this same mount. I tried to twist my neighbors arm to let me have it. Be he goes in the ditch too much and insisted he needed it.
Edit: photobucket works fine for me on other sites. It is what it is...
