Front Dana 60 on M1031
Jozseph
New York
Which TM has the assembling spec for the Dana 60?
Have been looking for the torque spec for the six spindle nuts to the Knuckle assembly.
Also the parts exploded diaphragm is not showing the disc/plate{I do not know the correct name] on the outer axle shaft, is there a part number?
Thank You
Joseph
Jozseph
New York
[SNIP}....."Also the parts exploded diaphragm is not showing the disc/plate{I do not know the correct name] on the outer axle shaft, is there a part number?".....{SNIP]
FWIW
I found out the following;
The metal disc/plate that are not shown in the exploded diaphragm are called "dust shields", "stone guards" or "slingers" - the "Dana 60 Axle Slinger", Spicer Part Number is 37308
Regards
Joseph
