- 16,396
- 23,308
- Burgkunstadt, Germany
Something else to remember about the convenience receptacle. While it is protected by the Ground Fault Isolator, (GFI) the main lugs are not. Always get them tight, but they are real easy to over tighten and strip the threads out. They are a PITA to when you have screwed the threads up. I have no idea why the military bought that non conducting wrench. No one in there right mind would fool around with the load terminals with the set putting out power. And with the rope attached to the set and wrench? Simply stupid.
