Tophatperformance
- 0
- 0
- Athens, Ga.
Wondering if I can use the Saginaw 710 gear on the outside of the frame rail running mrap wheels with 395/85/20s. Anyone got the setup? Do they rub? Please give some feedback.
thanks!sorry for the wrong orientation of the first pic. Loaded correctly, now can't change it.
(fixed it for you)
Not sure what pitman arm it is. Bought the kit from Waterloo Specialties. No wheel spacers.Wow that's tight! What pitman arm are you using? Do you by chance know the part number? Also are you runnin 1/2 adapters? Wonder if getting a 3/4 thick one would do the trick? Thanks for the help.
Love the snow!Yes I am. Can't get the closeup pictures to load from work so will try from home. Will measure as well.
I'm using A3 wheels.By wheel spacers I mean adaptors used with the mrap wheels. I thought if I made those thicker by1/4 it would push the wheels out that much more. I know they would be heavy.
