I'm in the process of working on 802a which had the injector pumps removed. I installed new pumps but can not get them to pump. I believe my problem is with the fuel rail. I can take the pumps out and feel the fuel rail and move it front to back with my index finger. But if I keep my index finger on the fuel rail and I try to move the fuel shut off lever to the On position (pulled back towards the generator head), I can't get the fuel rail to move back. If there is no pressure on the fuel rail (from my finger), the fuel shut off lever will move it fine but with just alittle pressure it wont move. I should mention, that I can move the fuel rail back (to the on position) with my finger and then move the fuel shut off lever to the off position and it will pull the fuel rail forward without any problem. So I'm thinking that the fuel rail can't move back to place the pumps in the on position. The TM doesn't really show what moves the fuel rail back and forth so I'm hoping someone can guide me in the right direction. I hope I don't have to take the front of the motor apart to get to the governor linkage.
