Jayco36REQS
- 2
- 16
- Orlando/FL
Ok, so I went to move the 5-ton the other day, and it was idling rough. Here in Orlando FL the temps are always mild.. so it's not a cold start issue. I let the truck idle to air up the brakes to 120psi, and put it in gear, and it felt like I was running on 4 cylinders.... low power, and rough as an old tractor. I stopped popped the hood, and poked around....
- No leaks
- No smoke in the exhaust
- Fuel pressure is good
- Oil looks good... aka no water/fuel in the oil
So I decided to take the truck for a spin around the neighborhood to see if anything changed with driving and heat. After the engine warmed up good, it smoothed out and started running smoother. By the time I got home the truck was running pretty much normal. So I thought... well maybe it was a burp. WRONG.
I went to start the truck again a couple days later and it was rough again... WTF?!?!
The thing is, this truck has been rock solid from the day I picked it up at the Indy depot yard and drove it back home to Dayton, OH.... It didn't matter if it was freezing cold, or hot, or rain... it always ran smooth. I drove it the 1,000 miles down to Orlando when I moved here, and it was great... ran 68mph all the way (except on hills of course..lol) Never got hot, never burped.. zero troubles... it just ran like a top!
Ok... so... any thoughts? Any ideas where to even start trying to figure this out? ANY ideas or thoughts are greatly appreciated!
Thanks!
- No leaks
Thanks!
