motorstormer
- 2
- 6
- Austinville VA
A sweet truck set up/ off road camping for my daily driver maybe some over land in the future.Are you planning on doing some overlanding? Or just looking for a sweet truck setup?
All of my gear including the one spare will be in the bed until the space is needed then tire, jack and whatever else I have can be throne on the roof, this way it'll all be locked up and out of the elements most of the time. I also plan on doing rock sliders, can they be bought for these trucks or will they have to be made? I really like the stock bumpers and don't want to change them. I hope to find a metal toper I think these utility ones are, so hopefully the weight of the roof rack woln't be a issue. Thanks for the pictures looks good but I don't want to use military antenna mounts cause I'm afraid I'll get them hung up on a tree.Motorstormer, where would your spare be sitting? How many?
What are you using to tie down your Hi-Lift.....any locks on it?
Rock sliders can be really helpful in the bush, and rocks.
Will save your rocker panels while providing a bit easier way out of trouble.
2am moonless night stuck in a grass obscured ditch 4 feet deep x 4 feet wide - two miles from the Mexican border.
Not a good place to get stuck,,,especially at night.
Multiple Hi-lifts are essential.
One to lift and one to push back into the opposing wall.
A "Pull-Pal" or some other type of land anchor is a life saver when there are no grab points for your
winch and the Hi-lifts won't do the trick.
Killer bumpers, front and back, help buffer against rocks and larger than life bushes. Lots of steel in those bumpers with well constructed and installed mounts
save your radiator and coolers to die a natural death from over use. You can always re-position the bumper after a hard hit. It's very difficult to recover from
a cooler or radiator fluid leak in the field because a less than stout bumper kissed or worse yet, punctured a fluid unit. If ya never leave the blacktop this will likely never be an issue.
Make sure the roof rack is well mounted with consideration to the weight load up top.
Don't wind up like some of the guys with a cracked/crushed topper.
My MPG and EGT readings tell me the weight load has gone up since this unit was scratch from the factory.
Time for a CAT scale visit.
View attachment 612658View attachment 612660
Cheers
Tire repair tools are also worth considering. You want to be able to patch a hole, replace a valve stem or a valve, break & set a bead, inflate a tire, etc. Tools & parts for this take up much less space & weight than a tire.I will be carrying two spare with the truck as my experience is always one goes and shortly after another one just happens to go.
My rock sliders were purchased in 2012 from "Shankem-Deep", a SS member.
Don't know if he's still making these.
Bolted right up to the frame. Rocker panels are very appreciative of Shankem-Deep's good work.
Sliders came with bolt on steps which I have not used. I think the steps would be a problem in the rocks or rough terrain.
Antenna mount brush guards have, so far, kept mesquite trees at bay.
