- 6,861
- 696
- Stratford/Connecticut
Its possible the dash valve has air leaking thru it. Does it look recently replaced?
It looks like it was removed recently. Can't tell if it's new. It releases air when I pull it outIts possible the dash valve has air leaking thru it. Does it look recently replaced?
I believe so but need to verify.Do the rear brakes engage when you are driving and step on the brake pedal?
I have one bad check valve for sure on the rear cross member. I need the check the others.What I would start with are the known bad valves namely the 3 valves under the driver side cab. I had one truck that bypassed air through the parking valve, while there were leaks through out the system. Once I replaced the valves the park brake stopped bypassing air.
That will be the second GP FMTV found to have crossed hoses due to mistakes made by someone within the military! "Sarge, this one cannot be fixed, send it to DRMO."
