- 1,450
- 119
- 63
- Gray, GA
I was pondering this today...for way too long actually, lol. Without a spare to disassemble I can't confirm but here are my thoughts.With the vent being removable on that Medallion shutterstat, can you move the swap the vent and input positions to change it from a normally closed to a normally open valve?
The Evans uses two stages to activate the fan. The capsule gradually warms, which gradually allows pressure to build in the shutterstat. When the pressure rises enough it activates a poppet type valve, which instantly sends full pressure to the clutch. This keeps clutch wear down by instantly engaging the clutch, instead of a slow engagement.
If the Medallion works like this, which I think it does since it must overcome the same problem, then I think the answer would be no. I don't think the two stages would work properly in reverse. Medallion does offer NO shutterstats in various temperature ranges though. If I can get my hands on another one I'll take it apart and see how it works.
The only one I have right now is on the truck though, and it's got to get me to the rally this week. My Evans had a major complication during its last surgery so I don't have a spare in case something goes wrong during disection of the Medallion .
