Horns
BenRoberts
Certified insane
1,367
208
southwest/ohio
The horns on my 923 were inoperable when I bought it and im looking to troubleshoot it but I dont know where to start. There is no movement in the horn pad on the steering wheel when I press on it which I guess would be somewhere to start.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
That sounds suspect. There is a section in the TM dealing with the horn but basically it's always hot and the horn button establishes the ground.
ralphluby
York ME
The horns are dependent on air pressure. Start up truck ,build up pressure and there is a good chance your horns will work
BenRoberts
Certified insane
1,367
208
southwest/ohio
The truck holds around 120psi but it did sit with the top off for a long time before I got it which leads me to believe its something in the cab thats got too much rain in it.
Wildchild467
57
Milford / Michigan
I also had the diode in the horn system go bad in my buddy's truck which caused the horn to stick on. good thing is that its not that complicated of a system. A basic volt meter/test light and flare nut wrench (to loosen the air line to see if you have air to the horn) and jumper wires should be all you need to troubleshoot. Like Recovery 4x4 said, the horn has a hot wire going to it and the horn button only supplies the ground.
BenRoberts
Certified insane
1,367
208
southwest/ohio
Ill tear into her this weekend, thank you for all the advice
The HUlk
Cincy, OH
I replaced my stock air horn with an aftermarket one recently and can give you some specifics on what to look for electrically:
As was mentioned with the ignition on there should be constant +24V on wire 26 at the horn. If not then the circuit breaker at the top engine side of the firewall just right of center is suspect.
When the horn switch is pressed there should be GND supplied to wire 25 at the horn.
BenRoberts
Certified insane
1,367
208
southwest/ohio
Now that you mentioned the circuit breaker it has me intrigued. I believe the horn pad is stuck down and id wager to say the breaker was pulled but looks like I got a date with the power probe this weekend.
BenRoberts
Certified insane
1,367
208
southwest/ohio
horns now work, The contact point where it grounds was so rusty it could not provide a good ground. Took everything apart cleaned it and its back in action.:cool:
