2016 Findlay Ohio Buy, Sell, Trade, Wanted
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Complete medium adjustable tow bars with all the correct pins and feet(and MWO collars welded on) no more available.
skytroop232
Galena/ Ohio
I will be bringing a bunch of non vehicle stuff, selling cheap. Couldn't find anymore MRE's though.
I NEED Deuce side rear view mirror assemblies. Anybody?? Mine broke!!
jpg
15
Boston, MA
I know this stuff is not likely available, but I figured I'd ask just in case.
I need half a dozen of these straps used to hold a litter in place in an M1010. I'd appreciate any pointers folks might have.
In the -20 TM they are: 37-0051 STRAP, WEBBING
I also need the large aluminum panel with the red cross for the side of an M1010. (I have only one.)
And finally, I could use a shorty tow bar rig with CUCV (1") feet.
natem
15
freeland/michigan
SOLD......... Passed along to someone who can't make it to the event.
natem
15
freeland/michigan
If someone is interested, I'll bring my 4cyl Mule motors.View attachment 615182
As per request some more photos. These are early motors. I was told they were take-outs for2cyl conversions. Both turn freely and are very complete.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
I decided I am going to sell my portable flood lights. I'll get some pics tomorrow and post them up. They are large and heavy so it would be nice to have a firm sale before the event.
treva2
ohio
For Sale
I have a few parts that I won’t be needing for my Deuce build:
6 HEMTT/PLS wheels $800 (I would like these paid for before I load then on my truck for Findlay)
NOS water pump $80
3 ½” aftermarket exhaust stack $35
PTO and drive shaft for winch $200
Deuce fuel tank and pump – working take off $120
Are you still looking for this? I talked to a guy last year at Findlay that had brand new kits in the crate. He was not a steel soldiers member. I think I have an email address for him. I will try to dig it up.
Yes sir, indeed I am. I would greatly appreciate that.
I have not forgotten about this. I found the email address for the seller and fired off a message. He replied that he does believe he has four of these kits -NOS in the crate. They are in storage, and he was going to check to see if there is any damage. I asked if he would like to communicate with you directly before the Findlay show to talk details, but he has not replied back yet. I will retry him.
gottaluvit
Well, thank you sir! I appreciate that. If he isn't a member of this site, I could PM you my email to give him if that works.
Speddmon
Cambridge, Ohio
OK it was a little longer that just the next day, but here are the pictures of the flood lights. When fully extended the mast rises to a little over 21 feet. What you see in the pictures is what is in each crate. With the exception of maybe the spare light bulbs. One of the masts has a broken piece on one of the support legs but that should be easily fixed if you know someone with a TIG or nice MIG welder, since the mast is all aluminum. The mast is heavy, probably 100 pounds or more.
Each crate has the 3 lights and a cable to descend down from the mast. As well as about 50 feet or more of #8-2 cable to extend back to the generator or power source and a short pigtail to attach to the generator. The mast and extension piece, "u" shaped spikes to drive into the ground as anchors and the crank handle.
As you can see in the pictures, I don't even have it fully extended and it is pretty darned high. They would make a great portable ham antenna tower or portable flag pole as well.
I'm asking $100 for one crate of lights, and $65 for the one that is broken since it will need repaired. We can talk about other options and trades.
DECONTAMINATING APPARATUS: POWER-DRIVEN, PORTABLE.
It is basically a water heater with pressurized delivery. The water pressure and temperature are adjustable. From briefly reading the manual, it appears that the highest pressure setting is 100 psi. As with any military equipment, it is heavy duty throughout. It weighs about 360 lbs.
It has a two-cycle gas engine that powers the pump and fan. The motor does turn with the pull rope. The water heater is multi-fuel fired.
The base unit appears to be complete. There is a vinyl cover included (not shown ).
There are no accessories (hoses, wands, nozzles, etc.)
Here is the complete TM: View attachment TM-3-4230-218-12-and-P.pdf
I got this on trade and I haven't had a chance to really go through it. The engine does fire if primed at the carb, but I have not hooked up a fuel tank yet. I did purchase a new water pump belt which was absent.
$150 OBO (I won't be bringing it unless someone shows a genuine interest. )
