Quiz on trailer tires
goldneagle
931
Slidell, LA
What model trailers take a Super-Lug 9.00-16 tires on 16" 6 hole rims? I know the M116 and M101 trailers can take the tires but not the rim.
Recovry4x4
LLM/Member 785
1,807
GA Mountains
M715 series. They are a 6 on 7.25 bolt pattern. There did exist an adapter to run these on the M101. Only thing I know of though.
Guyfang
23,306
Burgkunstadt, Germany
I saw these type tires mounted on generator trailers. It was the PU-801, TM 9-2330-392-14&P, HIGH MOBILITY TRAILER. I am shooting from memory here, am almost sure this is right.
rosco
Delta Junction, Alaska
The old time "civi" International & Dodge 3/4 & 1 ton's used that wheel hole pattern, but mostly were found with the lock rings. Some one piece wheels did exist, as I once bought a "Binder" 3/4 ton with 16.5" tires. Mostly the 1 tons had duals.
goldneagle
931
Slidell, LA
These are 16" not 16.5" one piece rims.
