- 179
- 19
- 28
- Gilroy, CA
I heard those caught on fire?
I believe that's why the newer version has an external ground wire instead of just grounding through the case.I heard those caught on fire?
How can you tell them apart?I believe that's why the newer version has an external ground wire instead of just grounding through the case.
Newer ones should have an extra ground wire that gets grounded to dash. Separate from the canon plug.How can you tell them apart?
Thanks for clearing that up. Looks like I was lied to.the "extra wire thing" is a load of crap. They are all the same, they all burn/catch fire/melt. Not worth it. I talked to the manufacturer one day, there is no "1st version/2nd version. I had one until it almost melted my wiring harness..
WOW! Talk about taking a simple switching device and turning it into one complicated, malfunction prone piece of crap.Call the manufacturer and ask.
Way more info on that switch than you may want to know...
https://www.ipfw.edu/dotAsset/239506.pdf
Great comment, and (so) heart felt! Frankly there is much about modern Fighting vehicles that leaves so much to be desired.WOW! Talk about taking a simple switching device and turning it into one complicated, malfunction prone piece of crap.
