1971 M35A2 Front Axle Boot Replacement
Boots787
Kirkville NY
Hello, Fellas -
I have two new front axle zippered boots with clamps, but would appreciate any information on actually replacing these boots.
Thanks -
Boots
VPed
307
Clint, TX
Since you already have the zippered boots, use them before thinking of getting silicone one-piece ones. Relatively easy to do. I have even done them on my five-ton. I can do one in about an hour now. Never even have to jack up the truck for the zipper style. Make double sure the clamp ring is properly seated into the groove all the way around.
Boots787
Kirkville NY
Thanks, VPed. Your post is good news for me. My M35A2 is pretty much a show truck, painted back to 1971 OD and so far, I have not used the truck in water, so feel that the zippered boots should do the trick for me, as I'm pushing 76 yrs old, but still going strong and double-clutching always.
~Boots
Tracer
14,108
Hawthorne, NV.
As stated zippered boots are relatively easy to install. Here's some advice when you reassemble, make sure the mating surfaces for your hubs, boots, and clamps are free of grease and oil.
rchalmers3
Half a mile from the Broad River
30
Irmo, South Carolina
X2 ... fighting the slippery parts install under a big truck is no fun. Make the surfaces clean and dry and the sealing task will work like a charm.
Rick
